Ok, so I am having a lot of networking issues getting my Road Hog 4 to talk with my laptop running LC Design. Anyone that could give some very detail oriented help would be appreciated!
* check IP Settings (easiest way is to run the RH4 as a DHCP-server, and let the console give Ip adress to your laptop) * turn of all Firewalls and Virus-Scans * install the matching version of the visualizer connectivity tool or install same version of HOGPC like you have on the console, this will also install the correct tool * turn off/disable all unused network-adaptors
Got them talking, oddly enough though it doesn't work when using DHCP automatically from my hog, I got it working by manually entering in IP addresses, thank you guys though it is appreciated!
