Why Cant i combine sACN + Hog net?
I understand why not to combine Art-net with anything, being a broadcast portal and going everywhere regardless of whether or not its wanted
But sACN is Multicast, it only goes where its needed.
The only reason i can come up with is if the network somehow overloaded, but if your using gigabit cable and high end switches you would have to have a lot of universes outputting, i havent done the maths but it would be in the hundreds.
In a theatre situation it can be hard to get 2 networks everywhere you want a console.
MA hvae their MAnet and sACN on the same NIC works a charm, why cant hog do it?
Thoughts?
