When Using ACN: * Clone DP to the backup console * Set the backup console to a lower priority on the ACN Outputs * Done ;-)
When using Art-Net: * Clone DP to the backup console * Depending on the Art-net Node you are using, you can now give priorities to IPs or Universes. If IPs is possible you can send on the same subnet/universes, if only a priority is possible set the first DP eg. to send on subnet 0 and the backup DP to send on subnet 1. Set your Artnet Node to these settings.
