Fullboar 4 connection with Hog4 PC
Hello,
I am trying to hook up my full boar 4 to be remotely connected to my laptop running hog4 pc. Both are running the same version of software. I have it setup for the FB4 to run into a wireless router then my laptop just connects to the router. When I pull up the PC software, it won't find the show. I have set all the network setting correctly in the console and pc software. Out of the console I am using the Hognet port and not the fixturenet. My question is, for the connectiong between router and console, do I need to be using a crossover cable rather than a normal Cat5 cable? Currently I am using a normal cat5 that I used with the hog 3 before we switched to 4. Any other things I should be looking at?
