Hi I am running the latest version of hog4pc on my mac bootcamp with with windows 7. I am trying to set my ip on my hog to connect to Capture Atlas on the same machine. I am using the loop back adapter but it grays out all my setting to set my ip. I can only set my ip by setting it in the loop back adapter but then that makes the same ip as capture. Since capture gets its ip from windows. What am i doing wrong? this is really annoying because it used to work perfectly before hog updated and got rid of the connectivity driver.
