Need Help Networking for Console Failure
Thanks in advance for your help!
I have a Road Hog4 connected to a super widget, running 4 universes of dmx out. Hognet is setup and running to a TPlink router. Hog4 PC is running on a surface 3 tablet and connected wirelessly to the router. The surface tablet is seeing the RoadHog (pinged it). Everything is set up correctly as far as I can tell. The Hog4 PC however is not seeing the show on the Hog Start show under Connect To Show.
I think I need to run the super widget via fixture-net probably right? If the console goes down, the super widget will go down because it's hooked up via usb to the console.
Both console and PC are set to port number 6600, run server selected, net number on console is 1, on PC it is 2.
Please help!
Thank you!
Jeremy
