Hoglet 4 USB Network Hub
Hi Hoggers,
I'm running a Hoglet4 through a PC I built. Since the Super Widget is built into the Wing, if i get a glitch or error and have to reboot the server, my Super Widget will go offline as well. Hence losing the look on stage rebooting... So I thought if I ran the Hoglet4 through a USB network hub, the hub will share the Wing between the server and my laptop Has anyone done this, and if so what usb network server did you use?
Rossmoor
