Hognet cant connect to local show
Hi there!
I have a strange issue running a rackhog as a backup on a tour.
First of all we had a issue with starting up the rackhog repeating after a few days of no use.
ive replaced the bios battery and restored the bios settings to its default.
Now its starting up again like normal but i got the strange issue of blinking on and off the tab between connecting current show in network and running the existing show of the console itself. it seems that the hognet adapter is turning itself on and off and on after a few seconds. all the ip settings are correct since ive changed them back to what ive had the system ran before. I have done a full system restore of 3.13 and still no luck.
is there anybody with the same problem and know what to do?
thanks!
Kaj
