Assert + locked faders
So today I was trying to educate myself using Hog4PC and Roadhog. Connecting and using was pretty straight forward until I got to assert some cues.
When I pressed ‘a’ on the keyboard of the laptop or assert on the hog the cue of the chosen list wasn’t asserted. Instead it asserted another cue in a different list. I’ve tried it witch multiple lists and still the same cue was asserted. Only an log off/on fixed it.
After that was sorted I faded some masters though command macros set from the console and the pc. At first I was able to take over the values by moving the fader to the same value but after a while I couldn’t. Even when pressing choose and using the encoder or using the fader in hog4PC it wouldn’t budge. Again a log off/on fixed it.
Does this have anything to do with network settings? Or am I just doing something wrong?
Roadhog net number 1
Hog4PC net number 2
Same ports
No hardware connected to the pc
V3.12
Thank you,
