If got a hedgehog 4 not n or x. it got a hognet port but i can't acces it in controlpanel settings.
Hello, most models of Hedge Hog 4 have the same hardware configuration with both ports, but HogNet is only functional on certain ones. The link below should explain it in more detail, but please write back if you have further questions. You might be able to upgrade yours by contacting your local HES dealer. It will depend on the manufacture date and serial number. Determine HedgeHog 4 Generation - Electronic Theatre Controls Inc
