A Few Hog 4 PC Issues and Questions
I just downloaded Hog 4 PC and I like the look of the new interface. I have a few issues and questions.
- The Pause/Break shortcut to change from Abc to MAP does not work on my machine. I use the exact same machine for Hog 3 PC and I have no problem switching modes.
- I have the older Programming Wing with only 4 wheels. With the new Hog 4 PC there are 5 wheels in the programmer portion of the front panel. When I select a fixture the on screen mapping of the wheels shows the five wheel positions but via my Programming wing I can never access the fifth wheel. Even if I press say Beam repeatedly I can never turn Focus with my programming wing.
- I looked for the Kinds setup to see if there may be wheel sets for 4 dial wings but I could not find how to open the Kind window. The manual seems to indicate there is a Kinds button but I don't see one on the front panel or a shortcut key - if indeed I could get that to work.
Kevin Montagne
