Hog 4pc v1.1.0 still crashes in effects engine
was hoping this would be solved in 1.1, but was able to replicate the problem immediately.
Rig: Mac Mini and/or Macbook Pro-retina (bootcamp, win 7), 2 Dell st2220 touchscreens, h3 playback and program wings, single uni widget and super widget (depending on show)
To Replicate:
connect all wings/screens etc,
open h4pc (also happens on all prior versions as well as H3)
patch some fixtures
open effects generator, and when in spreadsheet view, if you set an effect, and then go to set the effect "path" the program immediately crashes (all windows close).
When this happens you are unable to restart it becuase some part of H4PC is still running and shoots an error message---
Hitting pic open delete will bring up task manager and allow a force quit.
The only work around I've found is to connect the usb for the touchscreens after opening a show.
Parents Reply Children
No Data
