I found a few bugs the other night...
My gear is Nano Hog, Sony Vaio touchscreen and Hog 4 PC...
When a chase is located only in the cuelist directory (NOT on a fader), you should be able to click and hold the cue cell, then dial in the BPM on the left encoder wheel. But when you do this, the BPM does not change...it only works when on the fader. It appears that this does speed up and slow down the chase, but the BPM read out does not change. This is a HUGE deal for me!!!!
Also, I am experiencing a random changing of "play, pause, play backwards" functions above each fader (ie: I set them to step forward, halt and step backwards and they will randomly swap functions. Ie: unwantingly change to nothing, step backward, step forward).
Anyone else having these problems?
