3.3.13
V1.1.1 b 337
Hog 4
Issue - On a few different cue lists, I recorded a blank first cue (cue .5) with a link cue following it. The goal here was to quickly be able to hit that master's go button while changing lists and have it jump to the new starting point of that list.
However, on the 4, you are unable to do this. If the first cue does not contain any information, it will not fire that first cue if that master is not chosen. It WILL fire it if you double tap the master's go button. It will also fire it if the master is chosen.
This is repeatable and shows up in various lists.
