Hey Dennis. What type of trackball are using? One of the Kensingtons? Cause there is no setting afaik.... Have you tried different types of trackballs/mouse?
neither nor. at the beginning everything worked fine, then it just flipped after restarting the console. even software update to .352 did not help... any other ideas?
Research so far: upper usb port under the fixture port inverting trackball and mouse, all other 3 ports working normal. when i boot the console with trackball in "bad port", up/down is inverted and when i change to another port then, trackball is no longer found by the console. Booting with trackball in any of the other ports will cause no problems! Even the "bad port" will work right when trackball was in another port while booting!
