Effects Rate on Cuelists Issue
Hog4 Console v1.1.2(339)
I have a couple of cuelist, each with a InvRamp Effect in Cue 1. While the cues are running, I ramp up the Effects Rate by holding Choose and using the encoders. I set it at 400%, which looks good. When I go to Cue 2, which stops the cue, and then back to Cue 1, the rate still says 400%, but it is not moving at that rate. When I hold Choose and touch the encoder it snaps to the 400% rate.
This also happens when I simply go into the cuelist options and type in 400% on the Effects Rate field.
Parents
  • Scott
    Thanks again for the information.
    This will be fixed in the 1.2.0 release.
    The root of the problem was adjusting the cuelist rate while in playback using the encoders or within the choosen masters playback options.
    We would not adjust the rate by 1% (or however big the change was) but throw in same crazy huge number.
Reply
  • Scott
Children
No Data
