Bug Report: v1.1.3 b352 Direct Entry of Encoder FX Values
Just discovered this bug. I have been able to replicate it on my PC as well. I don't think this is by design.
Hog 4 Console Running V1.1.3 b352
Steps to replicate the issue:
Record a cue with moving lights running the circle effect. Open the cue in the blind editor, select your lights, press effect, hold set and touch the effect size toolbar window and type a new effect size, hit enter. You will see all functions in the Effect Engine start a sine effect at varying sizes. I understand that the fx size toolbar defaults to the ALL row of the FX engine, but if I type a value in the size column of the spreadsheet it does not start a sine on all functions.
:hogsign:
MJ
