How can I adjust brightness of the LCD screen on Road Hog 4? Holding down the setup key as described in section 3.1.4 of the manual doesn't work with the latest software (v1.2.0 b540).
Thanks for the information, I will make sure we correct the manual. The current shipping monitor in the RH4's does not support dimming. Currently to adjust the brightness of the monitor you can go into "User Preferences" and adjust the "Brightness" and "Gamma" setting. Hope this helps.
I have connected an external screen to the roadhog, and adjusting the brightness and gamma only has effect for that external screen and not the internal one. software 1.2.0
Can you please tell me the model number and type of external monitor y'all are using? I was testing with H4 Playback wing and we only change the "internal" not the "external".
