[QUOTE=Sharpsynth;67993]Trying to find a way to create a inverse sine wave to make my lights spin counter clockwise, anyone have any luck on this so far?
Is it a Circle FX that you want to go counterclockwise?
If you want to change the direction of the circle rotation. You need to invert just one of the fx components of the circle fx. So load just the default circle fx. Reduce the size of both pan and tilt to something manageable. Then pick either pan or tilt and change the offset to add or subtract 180 degrees from the existing value. I'm not in front of a desk, but in theory this should work.
