I think about this every time I patch yet forget to post.
When patching dimmers in the fixture window (View by DP), once you get to about dimmer 22, the lines run off the page. So when adding dimmer 23, I have to scroll down the window to verify. BUT, I can't scroll down further in anticipation of the next 22 dimmers.
Once I patch dimmer 24, I can scroll down 1 more line.
Suggestion: a "follow chosen" type setting that would put the last patched dimmer on screen.
Or, making the full height of the fixture window available initially instead of 1 line at a time? Then I at least I could 'page down'. My current workaround (when I remember to do it) is to patch 512 dummy dimmers to an unused universe so it draws the full height of the window.
