I tried to install the new software 1.2.x and during the installation the system stops at 50% during the partition set-up. I used LiLi to export the file to USB. Any ideas how I can solve this?
Redo the USB-Stick Make sure that only the options mentioned in the manual are checked in Lili. In newer versions of Lili there are some options checked when starting up the software. So ony format stick should be checked.
