I should also add that H3 shows can be loaded into the H4. Once a show has been launched on H4 it will only load on H3 if the H3 is running 3.2.6 b3434.
[QUOTE=michael_graham;68559]I should also add that H3 shows can be loaded into the H4. Once a show has been launched on H4 it will only load on H3 if the H3 is running 3.2.6 b3434.
I would add that the best way (in my opinion) is to merge your Hog 3 show into a new Hog 4 show.
