Hog4 1.2.1 b550 and Hog4 PC (Same Ver).
Reference pallet doesn't refer individual values after change from global pallet.
Patch several fixtures with one type.
Make pallet as global (I.E Pos1 All pan and tilt as 0%).
Make reference pallet as global pallet (I.E Pos2).
Open original pallet (I.E Pos1) and gave individual value to all fixtures.
I.E 1st fixture set as Pan 1% and Tilt 1%, 2nd fixture set as Pan 2% Tilt 2% and so on.
Then update original pallet.
Select all fixtures apply reference pallet.
Open programmer and Output window.
You could see different value on these windows.
This is the second issue.
In the Programmer window, you could see individual values.
(I.E1st fixture set as Pan 1% and Tilt 1%, 2nd fixture set as Pan 2% Tilt 2% and so on)
In the Output window, you could see all same vale that I set as a global value.
(I.E all fixtures has Pan 0% and tilt 0%)
And when You record it.
You could have all same vale come from global.
This bug was tested with Position and Beam directory.
Aki
