Not sure if its just my board or an os bug. When I try to move a cue I get an error. "Unable to retrieve object for ID95 from directories array". I can grab cue # and copy then delete the old one but on 3.2.6 I was able to move cues no problem.
[QUOTE=srautane;70650]It's a bug and will be fixed in the next update. Also you cannot renumber cues, because of this bug.
Actually what we fixed is "In-place edits to renumber cues are not working in select lists on certain shows". This is D-1342 and is indeed fixed for our upcoming 2.0 release.:o
[QUOTE=lessergreater;70646]Not sure if its just my board or an os bug. When I try to move a cue I get an error. "Unable to retrieve object for ID95 from directories array". I can grab cue # and copy then delete the old one but on 3.2.6 I was able to move cues no problem.
Hog uses a custom database format to store your show. These type errors typically indicate a "can't happen" type situation, such as a cue but no corresponding cue body.:eek:
Our 2.1 release will be recording some diagnostic information about show history such that when we receive one of these showfiles from the field we can begin to understand how things get out of whack.
In the meantime if the problem persists I would suggest merging into a new show. This has the side effect of creating a new database which often cleans up these types of issues. :outtahere:
I thought the error was caused by the same bug, cause when you move a cue or edit the number, the cue number changes. I have a couple of shows where I cannot move cues and edit the numbers. It seems that things were not that simple...
It's possible that the fix for the renumber will also fix this.:)
