Hi Guys,
am testing v2.0.0 (b509) on a RoadHog 4 and there seems to be a bug with the kind mask.
1) I've set my Position Directory with Position and Beam permission enabled.
2) I've selected a fixture with all values of position and beam activated.
3) When I hit Record, Kind Mask and manually deselect all other kind mask except Position and choose a palette, Pos and Beam values were recorded into the palette.
However, following step 1 -2 from the above.
When I hit Record, Clear Mask and enable Position, only Pos values get recorded into the palette. This is result I expect to have and I thought I would get the same result as well when I manually deselect kind mask from the above example.
Is this correct? Please advise. Thank you.
