1.2.1 & 2.0 on the same computer / Pause-button functions
Hi!
Is there a way of having both 1.2.1 and the new 2.0 HogPC-software installed on the same computer? Right now 2.0 is overwriting the older version.
Can this be resolved with different User Accounts?
On H2/H3 the Pause-button had two functions: first it paused an on-going cue and if pressed again it would function as back. I can't get this to work in H4PC... Does this have something to do with H4 having a dedicated back-button?
I'm currently working with H3 Playback/Programming Wings.
/Michael
  • [QUOTE=MKratt;71294]
    I would doubt that you can have two versions of the same software installed, even with different user accounts since H3/4PC needs Administrator privileges to install. Both H3PC and H4PC will overwrite any older versions. You can have H3PC and H4PC installed together on the same machine.
    Check your options for the "Pause" keys....you may have it set to some function other than "Halt".
    Hope this helps. :)
