Finally had courage to upgrade to 2.1.0
I usually don't hurry to get things updated, cause my shows are old and originate from Hog3 version 3. something
The upgrade was smooth, except I had to battle a bit to get the DPs update.
I noticed running the DP update with fresh show and settings where you have internal DP off and DHCP on seems to work well.
The only problem I have had now after update is that I get sometimes HogClockInit error when I Log off and there's no way to get out from it but reboot.
Has anyone experienced similar error?
I noticed the new cool network window and It would be nice to have some enchanments.
There could be also fixture-net address, and icons/text which shows is MSC in/out on, Midi notes on, OSC in/out on, CITP on, Catalyst on...
