Have a set of atomic 3000s, want to program a cue to have the strobes blast in like a blinder and slowly fade out.. Done this on MA, but not sure about hog4. Any suggestions?
fixtues, at full, turn up rate and duration. Record, . @0, Record, -- set a fade time on the 2nd cue, and make it a follow cue with a time of however long you want the blinder @ full effect to last.
The same way you would do it on the MA2 is the way you do it on the H4.. Record a cue that has strobes at full at zero uptime. Set bump/executer to fire that cue on button down and on button up release/out. Then set release/out fade time to what ever you want your out fade to be on the backside of the hit. During playback, press duration sets strobe @ full duration and release starts strobe fade out for release fade time.
