Is there a way to edit the fixture so that the White LEDs on the Aura aren't controlled by the overall intensity. I would like to have individual control over all four colors with the encoders. I also would like the color mixing engine to be RGBW instead of CMY with a white.
Also used Auras without any issues... RGBW will only be available when you use intensity.
The realworld-parameters of HOG OS are always layed out to CMY, this gives you the best result when you need to use the change type option. Thats why it is CMY with a white.
I am using the Auras in extended mode and they are working fine with the two profiles. I just don't like how the Auras turn on the white LEDs when I apply an intensity value to the fixture.
Just a note to say you can change the colour mode of these fixtures from the desk. Can't remember if this affects the white but suspect it may as it adjusts the white balance of the fixture.
Ross, this what I have thought as well. And if I remember correct it will affect the white. Under control mode you can find: colour raw and colour cal. This needs to be selected for about 2-3 seconds to change
