Hello Help me please, I can not remove from the scene of the play sheet hog4pc scenes, I use the regular keyboard pinching scene + z key on the keyboard but the scene is not removed from play, what do I do?:hogsign:
I tried with V2.1.1 HOG4PC and couldn't get the scene to release. The only way I could get a scene to release was Releasing All (ALT + Release) or (Pig + Release)
Dear developers, please correct the problem release scenes in HOG4PC, yet we are able to do only release all the scenes but this is not enough, please give us the opportunity to make each scene release sheet scenes of not only all but separately. Thank you.
I tried on H4PC as well and there is something strange going on here. One thing I found that will get the Scene to release it to select it, then hit Release. Definitely something to take a closer look at here.
[QUOTE=asia559571;73157]Press and hold the scene then hit release while scene is depressed.
Couldn't "HOLD" the scene palette down on HOG PC. 'SHIFT" + "Scene" then "RELEASE" releases all scenes not the one.
"One thing I found that will get the Scene to release it to select it, then hit Release"
Couldn't get this method to work either. Using HOG PC 2.1.2. Tried on an Intel i7 64bit Windows 7 machine and on a Boot Camp Install of Win 7 on an i7 Mac. Same results. Tried with 'Guard' both on and off.
