Seems to be broken in 2.1.2. I went right from 2.1.1 (which was a fresh install) -- Playback wing 4 connected to display 1. Will not calibrate ... have restarted each and every time.
I have tested this again today with a H4 and a playback wing. I ISO'ed the desk to 2.1.1 then using the fpspkg upgraded to 2.1.2.
I had everything setup and working and then just upgraded after the upgrade everything was still working. I then re-calibrated and again everything worked as it should.
What DVI port are you plugged into? Did you have everything working and then just upgraded and after the upgrade the screen was not calibrated?
Screen plugged into the far right (single) DVI port. It wasn't working all the time on 2.1.0 or 2.1.1 (typically would lose calibration (only the wing) after a shutdown or reboot. Normally not an issue (other than annoying) to recal and it would work.
Any particular reason why we would STILL have to reboot on screen recal? Also, if you recal from the main login screen it doesn't ask you to reboot (nor does it save the settings) -- if you do it from control panel it does.
Still having random calibration issues with external wings attached. This weekend I had a playback wing attached to the far left DVI, (playback 4) and i would calibrate all of the screens but the REBOOT option would never show up. Rebooted manually and the calibration wouldn't stick. Tried it from both within a show, from the control panel at the startup screen and the touch option.
Can someone provide some feedback on what the issue seems to be?
I have bigger fish to fry, the screen is bunk. Once I fired it up it looked all 8 bit ish and then cleared up but now its on the fritz. Is this thing under warranty?
