Hi, I am not real familiar with the fixture but looking in the manual, for each fixture you will patch 1 x Motion, 4 x Cells, and 1 x Beam or similar for each fixture. Each Ring will be a different fixture number. This is the way the Hog software handles LEDs with multiple cells. As there are different modes it can be run in, you will need to confirm the fixture is set for the same mode as what was patched.
