OK here's a fun one:
Is it possible to copy AN ENTIRE ROW from one parameter in the effects editor & paste those values - table, rate, size, etc along with any pre-recorded grouping - onto another parameter?
For example:
I tossed together a nifty little tilt effect a few days ago, and am wondering how it would look to slap the same pattern onto the dimmers. Of course, I can't recall the exact grouping/buddies/offsets that I stumbled upon originally for that nifty little tilt effect. So it'd be marvelous if I could simply pull some sorta quick copy/paste trick from tilt to intensity.
Any suggestions?
