ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
More
Hog 4 Lighting Controls
Hog 4 OS Software Discussion
Loss of HTP on slider.
More
Cancel
State
Not Answered
Date
frankfraley - Former HES Forum Member
Date
Tue, May 13 2014 8:30 PM
Replies
Subscribers
8 subscribers
Views
Users
0 members are here
Options
Share
More
Cancel
I up dated to hog 4 v2.2.0 from 2.1.2 But the HTP will not work. The lights drop to 0 and then go up with the slider. I went back to v2.1.2 and it works fine.
0
markn - Former HES Forum Member
over 8 years ago
It works fine on my desks.
If the fader is at 0 and you press clear after recording the HTP the lights will go to O but raise in intensity with the fader.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 8 years ago
I have one Que with the lights at 60% and when I bring up the slider with the lights set HTP it makes them drop to 0 first not just start a 60% and go up.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 8 years ago
The only way I can make what you're experiencing work is by pressing play on the HTP fader.
Have you got the "Use HTP" box checked in the playback options? If you have, you don't need to press play and you will see a yellow H in the cue list bar. Sorry if you know this, I'm just trying to help!!
I've currently got a light at 60% in 1 cue list on my desk and have the same light on a separate list set to HTP and it works just as it should.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 8 years ago
Do you think it could be the board you are useing it on? I am running hog 4 PC. I will try to play with it a little more when I get back. I am not pressing play all I do is push the slider up. Thank you very much for your help.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 8 years ago
Hi Frank,
It shouldn't be anything different. I'm sat in front of a Full Boar4 but I'll try it on the PC for you as well.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 8 years ago
OK thank you very much
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 8 years ago
Just tried it on HogPC and it's ok there too, again, the only way I can get the light to drop to 0 is to press play on the HTP, which you don't have to do if the list is set to HTP.
In the playback options click on the master tab and make sure "release at 0" isn't selected.
You probably know this but when your HTP fader is at 0 your cue should remain live, the way to tell is there shouldn't be "...." above the cue number, if there is, something is releasing that cuelist.
Hope this helps.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 8 years ago
Yes it does thank you i will test it when I get back. Thank you very much.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
Top
