After doing an update I press go or flash with fader in the full position it does what its supposed to. But when I manually pull down the fader it doesn't dim. It go's all the way down to zero than lights shut off. No dimming. This happens when the play or flash button is hit and at that point I lose manual dimming ability. Fader just shuts lights off at zero anywhere in between lights stay at `100% full.
It is set as IPCB. I have a NANO HOG4 board. I updated the software to the latest version and this fader thing happened. It only started after the update.
Just so I understand: Fader is set as an IPCB List has a fixture at full You put the fader to full and then hit the flash key After hitting the flash key you cannot dim the fixture by pulling down the fader
I was able to re-create the problem. Once the list is played it appears we are unlocking the fader (and not showing you it's unlocked) and we are locking back on once the fader hits 0. I have logged a defect for this but it will not be fixed in the upcoming 2.3.0 release as we are finishing it up. I will push HARD to get this fixed in the next release after the 2.3.0 release.
