This is the first I have heard of a slow down when performing a goto. What version of software are you running and what console are you on? Do you have a show file that this is a problem on? if yes can you send it to me?
We're running a full boar 4 with V 2.3 We opted to go with a clean install when the new version came out since we've had issues a couple of times in the past with the upgrade path. I'll send fresh backups from tonight to you. Mitch might still have the files hanging around from another issue a couple weeks ago he was trying to help us with.
Edit: Sent via wetransfer let me know if you don't see them
I think some of this slowness might have been due to lack of look el optimization which is something that can now be fixed in v2.7.0 and greater using the "compress show" button in the shows window. If you run into this I would give that a shot.
Yup 2.7 and the compress has indeed helped the issue. Going to watch and see what bugs are coming up in3 for a few days before upgrading. The desktop crash while recording would have been a great fix to have a couple weeks ago while programming the new show here ;-)
