This is the error message I'm getting after upgrading the software to 2.5.0 when I try to clone the internal DP on a RH4 to an external DP8000. Also get this message when I'm trying to just patch to DP. It's messing with my mojo a considerable bit, as you might imagine, since this rig is not suppose run any DMX off the console.
I just looked into this on my test units and could clone the internal to an external dp with no problems. Is your external DP sitting Idle or is it active when trying to clone to it?
