After issues like this last week and the weeks prior I have created a new show file on two occasions and imported what I need via show merge. Same issues persist. This has repeated on Hog4, two separate road hog 4's, and today for the first time hogpc. Here is today's example.
- I turn on the Road Hog4. 2.7.0. There is no external DP.
- I turn on Hog4pc to run not as a server and connect to show over network
- I try to run a cue from a cue stack and the stack still shows ... with the cue I tried to run under it.
- P-O-Back reveals the DP8k has stopped responding.
- I restart the DP8k process.
- I make a couple of changes in the programmer. Then merge into cue. Then desktop becomes completely unresponsive.
P-O-Backspace shows nothing abnormal. I restart Desktop. Everything is functioning properly. But the two fixtures I had in the programmer prior to the desktop restart are in a phantom programmer still. I select those fixtures at their values, then knock them out, and all is fine again.
This has happened twice today, twice yesterday, and sporadically in the past few weeks.
Any ideas? I don't see anything strange in the log, not that I'm an expert in debugging.
