Sorry Guys if that might have been reported before:
Console: Hog 4 + Playback Wing
Os: 2.7.0
No more externals
So I recorded a lot of Masters (and so Cuelists) with Intensity only, set to HTP.
When you try now to open this Cue to edit the fixtures you got within that HTP Cue the Cue is completely empty. But the Cue still works as it should, means all fixtures you programed into are still there and work as they should.
If you simply add the fixtures you want to this cue and press update the cue will playback only your added fixtures, everything else what was before within has left!
The only workaround is actually to add with MERGE or if you want to remove via RECORD REMOVE..
This happens only in HTP Masters (And Cuelists, did not try out Scenes with that)
Best
Rolf
