Bug Report - v3.0.0 (b1049) - Roadhog 4 Grand Master
On a Roadhog 4, with fader 1 covered with a list, holding the GM button down does not reveal the Grand Master on Fader 1. However, the fader still reacts as the Grand Master.
You are seeing this consistently? Like right from show load? We aren't able to reproduce this. What about the display on encoder wheel 1. Is it showing the gm level when the gm is held?
Yes…it was consistent yesterday. The first encoder was correct and would switch to GM. Like you said in the other one, maybe it's tied to the refresh of faders.
I'll launch the show today and see if it's still there.
Ok Jon, this issue and the other you reported sound like the mysterious and frustrating issue we've been chasing where the playback bar stops refreshing for fader events. What we have found is that it is nearly impossible to reproduce as well as fixable by simple log off/on. Now, with that said, we would love to gather as much data on this as possible so we can maybe finally understand what is actually causing it.
