BUG - Led CMY Intensity Dips between lists (specific conditions)
Full Boar 4 (3.1.0. b1078).
To Repro
Put RGB Led fixture (tested with all size Color Forces and TRX Color Blasts) in a CMY color, intensity at 80%. Record on a new list, fader 10. Also Record on another new list, fader 9. PLAY on fader 10. Play on fader 9. Intensity will sharply dip and then fade back up to 80%. Same when going back to fader 10. Seems to be releasing the stomped fader quicker than the new one is fading up, but only for intensity.
Notes:
*cues are exactly the same so when stomping and releasing each other, there shouldn't be any discernible change. It WILL, however, behave as expected if both cues have intensity at 100%.
*Doesn't seem to exhibit this bug if color was created with HSI.
*Same behavior with internal vs. external DP
*Didn't get same bug with Martin Viper performance, Mac Aura, Desk Channel profiles.
*Setting both cues to 0s fade also avoids bug.
