Multi element fixtures
Hi Guys,
Just wondering what the best way to patch fixtures with decimal points is, is there a way to use THRU to cascade the decimal numbers?
I'm doing a show with a lot of Chauvet Nexus 4x4s and patching them as 801.1 > 801.16 per unit.
When I use the command SET 801.1 > 801.16 it inputs 801.1, 802.1, 803.1 etc... is there a correct syntax for this function or does it not exist? or is there a better way to be patching these fixtures?
Chris
