Check the requirements for pc here. Find a pc with at least double all the requirements and you should be good. This shouldn’t be hard. Also, make sure it has an Ethernet connection and go ahead and get a USB to ETHERNET for you console.
One thing to make sure of is that you solely dedicate your PC to your console. This means do not use it for anything else. Keep it offline when possible.
