I think I have this recreated accurately. I have just upgraded to 3.2 from 2.4 on 2 separate Road Hogs. Each running their own separate show file and not networked. Here is the issue:
When there are multiple head numbers with changes in the programmer and out of those changes, I want to just take the last number selected and re-record an existing group. That channel is highlighted and I press "Record" and touch the group to replace, Touch "Replace" when the prompt pops up. At this point the command line is unresponsive. I can't backspace, enter any more numbers or use the keypad at all. My fix has been to Pig+Open+Backspace (this works), and hitting OK when the window pops up. I will then get control back of the command line meaning I can now backspace through the command line whereas before nothing would happen. I've had it happen 3 times today so far, twice on one console and once on the other.
