How do I add shortcuts to the 12 Button function keys on the HH4? Also, if you close the Function soft keys on the screen, how do you display them again?
If you want a mix of functions and wheelsets, you can leave them in Command mode, and attach a macro that changes the buttons to Kind mode, presses the wheelset, and then changes back to Command mode. It's a bit clunky, but if you edit the timings within the macro, it works well enough.
