Missing Operating System
ROADHOG 4
its up to date running version 3.2.0
so I seem to have had a lot of issues with this clubs console. the system crashes quite frequently.
It struggles when an ipad or laptop is connected to the network and quite often crashes where I lose the playbacks or sometimes it clears the whole screen, so its just looks like the background where it becomes unresponsive.
I also use two playback wings which, when I used to start the console, only one (never the same one) would not switch on till I removed the usb and plugged it back in.
I downloaded the system restore/full install, It seemed to work till after i shut the console down ad switched it back on.
Now the only way i can make the system work is by doing the install every time I switch it and let it reboot
I do unlpug the keyboard and the usb when prompted to do so.
Does anyone have any ideas or some helpful advice?
Thanks a lot.
