Is the a way to see/tab over to the fader wing on the HOG 4 All OSC template? Is there a button that I am missing. I know there is a faderwing only template but I need programing buttons. Also on the faderwing template there seems to be an issue with the play button? Any fixes on this would be awesome!
Instead of hog/hardware/go/1, you change it to hog/hardware/go/11 (and repeat for faders 11-20). You do that to play, pause, back, fader…double check all the buttons and faders, and you should be good to go.
