macro's
Hello,
I always use cue list with links in it to use it as a chaser. But i wondered if you could make group intensity macro's in your cues.
the way i prog now:
cue 1, Dim
cue 2, link cue1
cue 3, 1-2
cue 4, 1-2
cue 5 link cue 3
so for to store this i use normal command lines like : fixture 101 thru 112 at 100
and i build macro's to go and release the chase on all the different faders at the same time.
it works awesome accept one thing: if i have additional lighting i need to program my chase again and again.
wat i really want is to use macros that refer to groups, so if i have some extra sharpy's i just need to add them to the right groups and all my chases will be perfect with out additional programming.
example:
cue 1, dim, *macro: group 1 at 100*
cue 2, link cue 1
cue 3 1-2, *macro:group 2 at 100, group 3 at 0*
cue 4 1-2, *macro:group 2 at 0, group 3 at 100*
cue 5, link cue 3
I know it is possible on a PRG but is it possible on a HOG4? And will it automatically update the playback's??
thanks
  • If you have more fixtures why dont you just replicate your existing fixtures.
    There is a request for what you have been asking, so that if fixtures are added to a group/palette that the console wil ask you if you want to update existing programming.
    But for the meantime replicate fixtures might help you a lot.
  • thanx for the reply! I hope hog wil introduce this feature.
    other question you might know the answer on :
    I always store my effects in the scene directory, and have written a macro to release them, it works great and saves faders space.
    But i would like to have an output master fader on my dimmer shapes. so if the master is at 0 i could tick the dimmer sinus in the scene and the master controles the output of the all the shapes i want.
    is this possible?? i would prefer to do this via macro's so that if i program 1 extra scene it automatically would be controlled by the fader.
    thanx
