What actual resolution is the pixelmap engine in the Hog4 running at? And what refresh rate? What format does it convert to internally? Im trying to cut down on conversion steps.
The refresh rate is the same as the DMX refresh rate for your DP. So if the frame rate of your video is 24fps but the DP refresh rate is NOT 24hz you won't see every frame in your video. The video doesn't play at the speed of the DMX refresh rate, rather a calculation is done to determine which frame to play.
