Does everyone in the group how to modify the cue it?
Update.merge or open cue editor?
I do not fully understand the different between the update and merge Cue.
Sometime I use Update to modify a cue and it will not to record new value.
If last  cue is a effect .and I update a new position or color value .it will lost new value and track from last cue date.looks like I press remove.
If I use merge .Can be successfully modified, but in time will add a new data
What is more correct cue correction method?
Thank you
